best map sensor hook up spot on rb26???
  • best map sensor hook up spot on rb26???
    hello guys i have a question on were to put the map sensor on my single turbo rb26 im using a HALTECH e11v2.Where is the best spot to hook the map sensor to? please help thanks for your time and have a great day.
    I have a Power FC D-jetro that uses 2 map sensors. I'm not sure if it would be the same place as a Haltech but maybe this will help.
    I have them on the 3rd and 4th intake runners after the butterflys. I have also heard of people tapping in to the balance tube.
      The balance tube provides a good average pressure without the fluctuations you see in the intake manifold.
      The Beaumont Connection
        so if i T them into one will it work even tho this setup is for a pfd d-jetro version? will it work for the haltech e11v2?
          Yes that's works as well. I know many guys running one map sensor and they T'd it into one.
          Does the Haltech manual not say how to set it up though?
            hey not to hijack but is the Haltech E11V2 a good alt to power fc? bit dated but im only looking for something straight forward.
