Okay i have been "googling" like mad to find the reason my car has started whining lately.
so far i think i have narrowed it down to a front prop shaft bearing? or front diff gears being worn out.
Heres the symptoms:
driving at about 60kmh when maintaining speed or accel it starts to whine out a bit, sounds similar to a low gear whine from a 4x4. Under DE-Accel the whine stops. No clunking, chatter, or other worrisome noises just whining.
Im not 100% if its the front diff, tranny, or rear diff but there is definitely a whine coming from somewhere.
So, any ideas? If it IS the gears/bearings are there any rebuild kits available that you know of?
IF i do need to rebuild this diff or repair etc, can it be done in the car without removing the the oil pan?
Replacement of the housing is not an option as ive got a deep trust sump pan that i dont want to hack off and re weld to a new pan, hense why i want to repair the internals.
On a side note, i have not checked the fluid since filling it after my engine install a few months ago, and i filled it with some penzoil gear oil. I could swap to heavy shock proof but it might be too late.
Heres the symptoms:
