Hi guys,
I'm posting an update on my car when it was running into limp mode (not being able to rev over 2500rpm) periodically for no reason, i found the problem and fixed it. I hope this can help others that's having the same problem. Here is the thread i've started last year about my problems and a few updates on the things i've changed.
here is the video of the car going into limp mode while driving all of a sudden.
This video shows the car at a complete stop going into limp mode and suddenly going out of limp mode.
Here is the fixed video, it was the pigtail or harness that was acting up. I changed over another set of connectors, thanks to Brian! I opened up the old harness and sure enough the ground wire (thick black wire) was a bit corroded. I guess it got wet somehow and built up a bit of corrosion.
thanks for all the help from other members, and hopefully anyone else that's running into this problem can fix it alot sooner than i did.
DOH!!! Gives me hope again. So in your video (driving) your car goes into limp mode for a lot longer than mine does. Was it for shorter periods of time in the past and just got progressively worse? Also was it a pain to get the clips apart to redo the wiring?
