im pretty sure i have a bad ground somewhere but cant find a wiring diagram. heres whats happening. i have a r32 gtr. if i turn my low beams on, nothing happens, if i continuously flick them on and off one or sometimes if im really lucky they will come on. i have ruled out the switch, if i unplug the headlight bulb, turn the headlights on there is a great signal with a test light at the positive connector of the low beam circuit ( right at the connector ) if i plug that into the bulb. nothing happens and then if i unplug it again the signal is now very weak and dim on my test light.
this happens on both sides. its like the ground on the other side of the bulb after the resistance is bad and its not completing the circuit properly. so.. looking for a wiring diagram or some insight on where the grounds for the low beams are. or if anyone else has some experience with the same problem what you did. its very annoying.
thanks
brett
thanks
brett
