I want to learn about the front/rear difference threshold for running a staggered tire/wheel setup on an R32 GTR (while keeping the AWD running). What is the primary cause of concern - diameter of the rim or the total wheel/tire diameter? If I measure the total diameter for back and front and they are the same (even if the wheels are different width), will this work ok? I am noticing that there is a constant 8-10% power being diverted to the front wheels under most conditions. This doesn't seem normal. Here is the setup:
Rear
Wheels - 17 X 9.5
Tires - 255/40ZR17
Fronts
Wheels - 17 X 8.5
Tires - 235/45ZR17
Do you guys think the above setup is alright for ATTESA or is the difference too much? If someone knows how to calculate the difference (if any), please let me know.
I am not sure if pulling out the AWD fuse from the main fuse box (in the engine bay) is a good idea and what ramifications it might have on the car in terms of front diff/driveshaft being impacted negatively or what not.
Thanks,
Munib
Rear
Wheels - 17 X 9.5
Tires - 255/40ZR17
Fronts
Wheels - 17 X 8.5
Tires - 235/45ZR17
Thanks,
Munib
