For all you users that have the said pump but do not run a sump extension id like to gather some info off you
Does your car see many track days/get driven very hard?, Are you running a restrictor in the block, if so what size?, Do you run a head drain? If you over fill your engine oil how much? and the most important have you encountered any oil starvation issue's running the Tomei pump with no extension?
Thanks guys,
Mark
Thanks guys,
Mark
(got all my parts when our dollar was at 1.14
) i use it with no sump extension just a baffle (nismo i think) and my car has only been street driven as well... but i also run a little more oil in the pan, have an extra head drain back mod and a tomei head oil restrictor... if your so worried someone was putting together dry sump kits on here not too long ago get one of those... sound like u got the funds anyways
