Having some issues with my GTR. Startedout as a loss of boost in 3rd gear, then progressed to second then to no boost at all in first over the course of a day. Idle is somewhat uneven now as well. I have searched for possible causes and have done a number of checks:
Coils good
Plugs good
No turbine bits in the downpipe/cat (R34 N1 turbos, so steel wheel but checked anyway)
No vacuum leak
Can't find any loose hoses around the ic/intake plenum, but gonna go back with soapy water to checkfor bubbling.
No MAF's to worry about, running Vipec
Not blowing smoke other than slight bit at startup
Boost controller lines seem OK
The only things I did recently was install a new steering wheel and an oil catch can vented to atmosphere. Caught no oil (Mines cam cover baffles doing their job - also no oil in BOV discharge like before) and I reconnected old hoses. Could that have screwed things up somehow?
Anything else I should check? Wastgate actuators? I'd have to take the dumps and downpipe off for that right?
Thanks!
Coils good
Plugs good
No vacuum leak
Thanks!
