R32 gtr , stock boost and turbos, stock downpipes with a full a/m 3" exhaust, hks front mount intercooler and apexi intakes.
I`ve been dealing with a crazy hesitation/misfire/ turbo shuffle for a while now and so far everything I've tried has only solved it for maybe a day. So far I've re gaped my plugs , re soldered the mafs and cleaned them , checked the tps with a multimeter , checked the coils they were all within spec at 0.7, checked the little springs on the coils as well they all looked fine and ive reset the ecu. Only things I can think of that i haven't check are the coil wires and the ignitor.
Normally the symptoms will kick in under light throttle right around 2500-3000 rpm or just as ithe car comes onto boost. It's been intermittent on and off for the last while. Some days it won't happen and others it will. When it does happen you can hear the bov going off repeatedly. It doesn't seem to do it if you floor it , it still reaches full boost and pulls hard its just when you're under normal acceleration under load. Revving the car in neutral there's no issues only under load does the car act up.
