ok,so I try to do a RB26DETT build this winter and will need some advice about that...
so,this is what I would like to do:
CP pistons 86.5mm
Eagle rods
ACL bearings
Cometic head gasket (maybe Tomei)
OEM gaskets,OEM water pump,cam belt tensioner etc)
Tomei Poncam B with adj cam 2X(valve springs should be ok,but what about lifters?)
GT4088R 1.06 turbine
ARP head bolts
some china exhaust manifold (its 200-300$,will reinforce it a bit and it should be ok...I put 10 or more china exh manifolds on projects and if u put supports for the turbo they wont crack)
some china 46mm wastegate (not Tial but its only 100-150$)
will do my own downpipe with screamer
1000cc injectors (found some new Delphi low ohm for cheap)
some china fuel rail with FPR
twin Bosch 044
some china IC (will do my own piping for that)
and as for SA ECU will go with VEMS (cheap,WBO2 is included...have that on my RS2 and few other projects)
now,what to do with standard crank? JUN collar?! (engine is 1992.)
Oil pump? (Tomei is to expensive,maybe N1?)
that should give me 500whp which is enough for Calgary summer driving (thats 3 days a year
)...and cant go here on Nurburgring for a weekend drive so dont need something race/drift spec...just to have fun doing the build.
thats about it...also,need some advice about good machine shops in Calgary for block/crank and head skim and new valve stem seals etc? (im used to zi german machine shops
thanks
CP pistons 86.5mm
Eagle rods
ACL bearings
ARP head bolts
twin Bosch 044
)...and cant go here on Nurburgring for a weekend drive so dont need something race/drift spec...just to have fun doing the build.thats about it...also,need some advice about good machine shops in Calgary for block/crank and head skim and new valve stem seals etc? (im used to zi german machine shops
)thanks
