Just wondering if anyone knows what their ignition timing map looks like, I know its very specific to each setup and you can never be sure what the best compromise(egt, boost, timing) is but I just want to get a general range as a reference
from what I read, rb's can handle a little more aggressive timing compared to other boosted small displacement engines
I've also read as far as gasoline is concerned, the ideal timing is around 30 btdc based on the burn rate of gasoline, a lot of it also has to do with head design and the distance between the 2 farthest points during compression. But I think thats limited by knock in a boosted application
there's also talks of tapering ignition timing when peak boost/torque hits and then advancing back to what it was past that peak
I've been doing a lot of reading on ignition timing tuning and again, I know you have to hit the dyno to know for sure but I just want to know what everyone is working with. I played with the timing a bit and have been very careful, the absolute highest knock reading I've seen is 18 and afr is steady 11.3-11.8 under boost(8-10psi)
