I was looking at some Brembo Mustang front brake kits today, I was pondering if we could make them fit on a GTR, the wheel stud pattern is the same, the Calliper frame bolts are about 15cm center bolt to center bolt on 05 and up cars and 13cm on older ones. My car is hibernating anyone have a calliper or knuckle lying around that can take a quick measurement?? These brake kits are priced quite well, it would be cool if it could be made to work.
Brembo front brakes
I've done the 2007-2010 Chrysler/dodge SRT8 brembo conversion which only ran me about $650
its a very viable and cost effective upgrade but takes some work with a die grinder
http://forums.gtrcanada.com/gt-r-tec...embos-r32.html
Thanks, there are two kits from Ford Racing one is a 13inch kit for earlier cars around $1100 US with rotors, the other one is the GT500 kit with 14 inch rotors around $1000 US with rotors etc, both are Brembo 4 pistons black, the GT500 one is a larger calliper, may have to do some test fitting in spring, would obviously have to make adaptors. Hmm
