I did valve clearance check on the intake side with Tomei Poncams B and everything was ordinary ( some shimming required). The cams were not fully torqued down. I left it alone and came back 2 weeks later for a second time. I torqued the cams to spec, and checked the clearances again. I found the intake valves on #6 remain open with no influence from the cam lobe. I didn't touch the springs or even remove the valve retainers before this. The #6 valves had around 0.5mm of clearance previously. Can anyone explain what is happening and if it is easily resolvable? I doubt springs would just start sagging out of the blue.
