I installed my HKS BOVs and now when I hit WOT, it stumbles and misfires to oblivion at roughly 3000-3500 rpm and 5psi boost. I have my anti stall map running on my emanage so venting to atmosphere does not cause an idle issue. The cross over pipe is capped where the factory BOVs used to be.
Do I need to remove the whole cross over right from the turbos out?
The car was running fine before, and if I slowly creep on the boost I get no misfire.
Sent from my iPhone using Tapatalk 2
