I have been working on my car getting it ready for a dyno tune this Friday. Been away working so I haven't had a lot of time to work on it. I bought a Vipec ecu off a fellow gtrc member as well as a set of denso 720cc injectors.
Everything is installed: Walbro 400lph pump, injectors with new orings, aem fuel pressure regulator, new spark plugs installed and mafs have been removed. Map sensor is t'd into the fuel pressure regulators vac line.
was hoping I would put the battery and fire it up, but no luck. I have hooked the fuel pressure regulator right after the fuel filter then to the fuel rail, where the stock fpr was. turn the key on and I have fuel to this point.
pulled a plug and it is dry. I was under the impression that the ecu is plug and play for high or low impedance injectors.
Is there any settings on the ecu that might be causing it not to fire? or anything needing to be done to run the denso injectors?
Help is appreciated.
Thanks
Thanks
