Sorry if this is an obvious post, but I've looked around and not found the info I'm looking for:
My car starts great, runs smooth and has good boost, etc... But, The last couple of times after driving for about 20-30 minutes of varied highway and city it suddenly starts to misfire, run rough and otherwise run like ass. This happened again yesterday so I ran the codes within about 15 min of getting home and got a 55 so all seems to be okay there. When it was running rough, I pulled over to listen from outside and could smell rich, stinky exhaust. I got inside and revved it expecting to see some dark smoke from the tailpipe but there was nothing at all visible.
I was sorting through some paperwork and found the previous owner had installed a $59 cat converter about 1.5 years ago to get it through an e-test ... think this pos could be starting to cause issues? I'm going to put a test pipe on it and see if this solves the issues before buying a decent high-flow cat.
Anything else obvious that could be looked at? I was going to double check grounding on the ignitor, cas, etc... just to eliminate anthing obvious too.
Since last fall I've put new NGK plugs in (0.8 gap), new coil pack harness, HKS hardpipe kit, general tune up and clean up some connectors, etc... I only put in Sunoco (Petro) 94 octane gas and have triple checked all vacuum and turbo plumbing and all seems to be good.
Thanks for any help!
