I've been having this issue for a while now and can't figure it out. I have no problem under full load in any gear with and hesitation, choking, stuttering, etc. When I cruise in 3rd around 60km/h and step on it boost is great then go shift into 4th and try and maintain the boost it feels like it hits a wall but then takes right off.
I can get it to do everytime in pretty much every gear when I boost and let of then boost again it stumbles and pops and starts flying like a rocket.
My brother also has a gtr that has a engine getting rebuilt so I swapped his Maf's first thing, no change, swapped his ignitor no change, I have replaced the plugs and gapped all plugs from 0.6 to 1.1mm at different times and found no difference. Fuel filter is new, timing is dead on, made up a boost leak tester and found no leaks even with a evap smoke machine.
So fuel delivery problem, misfire under light load or what?
