hello I am having a misfire issue when the car gets hot
,however it runs great when cold will misfire as soon as it gets hot, cylinder 4 fails then sometimes it will be fine again I just put new plugs in but it was also doing this with the old ones I checked the coil pack and I still get spark, it seems that it may be the injector or injector plug cause when I push on it hard while engine running it seems to come back on ( cylinder 4), I checked theat plug and it is a little wet and then i checked cylinder 3's plug and it is dry and white but clean from what I understand a white plug indicates running lean however as soon as it drops from 6 to 5 cylinders all you can smell is gas so wouldn't that be running rich, so is there a way to tell if it is the injector or plug itself without pulling the injectors out , also I am missing 2 exhaust studs and the car holds boost steady at 14psi and my vacum is at -15 also my speedo is behind (slow) which is also a new problem basically I'm just looking for any feedback before I start spending money for parts that I may not need thanks
