Hey guys,
I'm having some issues that I'm really scratching my head over; to be honest I'm completely baffled. I've messaged Matt at Nistune and he didn't have much insight in to my issue either. Here are the facts:
- R32 GTS4 w/ R33 RB26 swap done in Japan. I've rebuilt the engine and have had it out a few times since I've owned it. Never had any issues like this before.
- About 50km before I pulled the engine last time (unexpected clutch issue) I swapped in new turbos and Z32 MAFs. I am using Nistune - Had no major issues with the car during that period, except, the K constant was not spot on so my fuel was a little rich.
- I put the engine back in with the same configuration/tune and now it barley idles. The AFRs are all over the place at idle (9.8 - ~15) and it is idle hunting from 1200-1400 rpm this gets much worse when it is warmed up. I again started a new tune and adjusted for the Z32 MAFs with no luck. Extremely unstable idle and will not take any load. (IE: pulling it out of the garage in 1st causes it to stall constantly)
- I swapped out my Z32 MAFs for the stock MAFs and put the R33 ECU back in. Now the car is idling really high ~1600rpm with some slight idle hunting and again the AFRs are all over the place - Mostly on the rich side ~10-~14. This does not surprise me though as I swapped to a Z32 due to these MAFs going really crazy with it was humid/wet out. Again, the problem gets much worse when warm.
- Using the stock MAFs with the Nistune has very similar results has when using the Z32 mafs. However, with this setup the cold idle is more stable.
- My O2 sensors are disabled. (As when you set the K constant in Nistune you have to do this) However, I was running a simulated narrowband from my wideband unit.
- I've replaced my temp sensore and checked the IAT sensor. Both are good.
- CAS does not have any issues.
- Checked for intake leaks. Replaced some questionable clamps.
- My "middle harness connector" is currently unplugged as the connector was damaged when I bought the car. This is what connects the IAC, cold idle valves and knock sensors to the main harness. I never had a problem running the car like this with the exception of the car stalling when going from high load to idle.
- Forcing the car in to limp mode (by unplugging the MAFs) the car runs super stable at 1000rpm, with he exception of the super rich limp mode aft (~9.8-10). I am able to move the car around my garage/driveway like this.
Now for the really strange parts:
1) My number one cylinder stopped firing randomly while using my Nistune ECU. Not sure why, I tried swapping coils and plugs and no change. I then tried my stock ECU and it worked perfect. When I plugged in my Nistune ECU it worked perfect again. I have never had this happen before and it has not happened since. WTF.
2) One of my Z32 MAF plugs just went bad. I can't even fathom why.. It always worked until now. I swapped plugs on the MAFs and it is definitively one of the plugs not the MAFs. I checked the wiring - all good. The pins are tight and appear to be making connection. It makes no sense. I swapped back to the stock MAFs and plugs and they send signals without issues. WTF.
This is where I am with it. I am at my wits end and if I can't get this sorted very soon I'm ripping out all the stock **** and running a megasquirt with a new harness.
Any thoughts? I really don't want to rip it all out if I dont have to.
