FIXED! - Issue was misfiring which was causing the shuffle. re-gapped to .8mm, taped some cracked coilpacks and its running better than ever now!
Alright i will try to make this as clear as possible... warning, a bit of reading ahead..so to start. I have been getting turbo shuffle in gears 3 - 5 under load while boosting for a few seconds. example.. traffics slowing, i dont want to gear down, guy infront of me changes lanes and theres no one for a mile now. I accelerate from 1800 (or so) rpm in 4th gear, ngines under load, turbos spool, then it feels like im hitting 100mph burts of wind every 1/2 second (or like the car is "chugging" and cant seem to get going). This only happens will under boost for a few seconds. i can boost great from 1 - 3 if im just getting up to speed from a stop. At first i thought boost leak.. then i thought coilpacks/spark.. neither made much sense. To me it seems like turbo shuffle from the wastegate opening and closing or something along those lines. Maybe someone can correct me if im wrong here?
Anyways, today i went to adjust my base timing and upon checking with the timing light it seems my base timing is approximately 20 - 30 degrees past the last timing mark (far right). i believe the last mark is 40 degrees, which would put me at 60 - 70 degrees right now. The car runs great (aside from the issue in the first paragraph) and idles/runs with proper a/f readings, CAS is centered and can be adjusted either way, timing belt was just put on about 1000kms ago and was set at TDC and all 3 marks were aligned with the belt markings. So what could cause the timing to be out this far? The only 2 possibilities i can think of are..
1. the timing belt is backwards, but this im sure would have destroyed my engine, and it would have never run? let alone as smoothly as it idles and runs now.
2. the motor is completely stock aside from 750cc injectors.. ECU has been chipped and tuned by the previous owner to compensate for the overkill. Timing may have been set like this in the ECU tune to compensate for 750cc injectors?
Any input is appreciated. It does not feel like a misfire at all, it feels like the car starts to "chug" along and cant get going, only while under load, at full boost (12psi), and after boosting for a few seconds. Thanks in advance!
