Hey fellas,
I've recently developed the dreaded high boost/high load hesitation.
First off it's erratic, sometimes (but rarely)not doing it at all.
Only happens above about .7 bar (running 1 bar without resitrictor. NO boost controller)
Boost gauge fluctuates while doing it (Nismo gauge)
The other funny thing I noticed is that my car has been sitting for 8 days in my garage. I went out today to change out the plugs and all 6 plugs were wet. Bottom of the threaded area and the tips...
Should they be wet after sitting over a week??
Wonder if it's related cause it does run rich, but no worse then any others I've seen, and it starts and gramma-drives just fine. Idles at a rock-solid 950 rpm. Throttle response off-idle is great also with no stumbles.
I've replaced the following:
Plugs NGK's at 0.8
new coilpacks
new coilpack harness
new CAS and set timing to 20 BTDC @ 950 rpm @ operating temp
New Tomei fuel pump
Checked endlessly for boost leaks (found and fixed a couple small ones but no change)
New Maf's and connectors
New TPS and set to .48v at idle, is 5v at WOT
Checked the rubber piping after Mafs, no leaks but pipes are pretty "squishy?"
I have 2 new O2 sensors I haven't installed yet, not sure if they'll help.
Only thing I can think is injectors. No external leaks I can find though..
Any ideas??
Rick
Plugs NGK's at 0.8
new coilpacks
New Tomei fuel pump
Any ideas??
Rick
