So it's about time I get aroun to installing a deck in my r32 gtr. When I got it it had a Jdm deck that would get any radio stations. So now I want to put in your average alpine off the shelf deck. I've read around on skyline Australia but nothing really concrete for my application. I don't want to chop the clips or the harness I'm looking for some sort of adapter harness that will be plug and play. I'm sure many of you guys have done this if anyone has any links part numbers or diys it would be great!
How to install a deck? (Radio headunit)
Ill take some pictures tomorrow. To to your closest audio store and ask for a 240sx stereo wiring harness. I can take a picture and send it to you. I have done it four times and worked perfectly. There is no chopping involved just some soldering and shrink tubing. I need to do mine this week as well and can easily do a DIY thread for anyone interested.
All you will need to solder is your deck to the harness. From that 240 harness you will be able to plug and play into any skyline! Ill take some pictures tomorrow to show you. Easiest thing in the world. Match the colors up, find your constant, ground and your off to the races. I think I even have the part number
Why solder a harness at the back of your deck when you can do the same thing with the harness on the car?
Once it's done on the car it will be good for any future North American decks you install in the car.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
Get it figured out?
Is it a stock deck in there or does it look aftermarket?
You can get the harness and adapter at any local car audio place, future shop, visions etc...
If you're going to Visions they carry metra harnesses/adapters
If it's stock this should be the harness you need:
Antenna Adapter:
If you're going to Future Shop they carry BestKits
(You do not need the dash kit)
Red: Switched 12v
Yellow: 12v
Black: Ground
Blue: Power antenna
Blue/White: Remote turn on (for amps)
Orange: Dimmer
Orange/White: Illumination
These are all your speakers:
Front:
White (+)
White/Black (-)
Gray (+)
Gray/Black (-)
Rear:
Green (+)
Green/Black (-)
Purple (+)
Purple/Black (-)
Wire your new deck to this harness color matching using butt connectors or solder making sure it's a good connection, plug it in and boom!
