Hi guys. I was drive my r32 gtr down the highway and everything was fine. Until out of no where my car just stop delivering power. The battery still works cause my lights and stereo still works. So I pulled over and now it won't start at all. And it was last night and it still won't start. I could feel my rad coolant bubbling when I pulled over so I assume it over heated but its been a whole day and it won't start pls help
Car just died need help
Compression check, coolant system pressure check, check end of dipstick for milky look, check for brown looking coolant in overflow bottle.
Then check fuel pump to see if it still works (when turn to I think was 3? on ignition barrel, should hear a small clunk sound after fuel pump primes), as engine could have gone lean, stock ECU compensated by pulling ignition timing, trying to run engine richer, etc (drop in torque, hp).
Dash should beep if battery is below 12 volts.RESPONSE MONSTER
Chrck your maf as well. If it goes you car will barely run. Trust me. Has all my wiring melt on me and it would barely start let alone run
Sent from my Z10 using Tapatalk 4 BetaCurrently rollin' in a 1997 Nissan 240sx こうき
