Hey ya'll,
Been trying to diagnose a problem. I'm getting a hesitation/slight bucking with partial throttle applied at cruising speeds. It only hesitates when it is hot (85 degrees + oil temps). AFR gauge will show an erratic reading spiking to full lean, back to normal, then repeats.
WOT - everything is perfect, spools fine, no hiccups or misses
Idle - Doesn't miss or bounce up and down, however it is leaner than usual [before was between 14.5-15.5 AFR at idle, now it is between 15.5-16.5 (sometimes will go higher to 17+ and feels like it wants to stall but only happens once in a awhile)]. Possible vacuum leak?
Thought it may have been a dead spot in the TPS, however, tried disconnecting it and still had the same problem when it got hot, ran great and smooth at 70 degrees oil temps.
The problem has gotten progressively worse, it first started with a slight miss/hiccup at 0 psi going up hills, but now it is doing it much more frequently on flat stretches as well.
Car has new plugs (1000km) and coilpacks (5000km Splitfires), new injectors and fuel pump (3000km on both).
Watchya guys think? Help is much appreciated, thanks.
