I recently installed tomie m76s and I'm not getting boost pressure just a vaccum when I rev it it doesn't go past 0 bar.I went over every connector loosened them all off and re tightened. I'm using a blitz dual sbc possibly the solenoid happen to die after I put in new turbos?
no boost pressure
Sounds like you're revving your engine when you're not moving haha. Get on the road man.Black 1991 GTR. Serious garage stand mantle/parts car.
Boost level can't go lower than internal wastegate actuator spring pressure. Is the vacuum hose to boost gauge map sensor (or what you are using to monitor boost level) connected????
Other could be a intake leak before MAF and boost cut on ECU is engaging earlier than it should.
Also are the internal wastegate actuators connected to the internal wastegates???Last edited by Skym; 08-30-2013, 04:05 PM.RESPONSE MONSTER
