Just wondering where I should look next to solve my problem. The car is fine cold, just when it gets to running temp does anything happen.
When idling, it hunts from 900/1000rpm to 200rpm. While cruising I lose power in 2 second intervals making it feel like I am tapping the gas. and when I push the clutch in to downshift or stop at a light the idle drops immediately and I stall. Yesterday as I was pulling away from a light my car misfired for a good 3 seconds
I've done a few things to try and fix the problem but none of them seem to have done anything.
So far I have:
Cleaned MAFs (In my trunk I found another MAF with a broken mesh screen)
Changed fuel filter
Checked coil packs
spark plugs
injectors
TPS voltage was good closed, open was 4.0
There are no thrown fault codes either
ANY help as to where to look next would be greatly appreciated.
So far I have:
Changed fuel filter
Checked coil packs
spark plugs
injectors
