So I was searching the board for normal oil temps on a stock motor and I read in a couple of those posts that people mention an aux fan that is suppose to kick on at a certain temp(and this is also running at the same time as the clutch fan is doing it's job as well correct?)
Now if I remember correctly, that is the same fan that is suppose to kick on when the ac is running as well correct?
Okay so lately I have noticed a couple of things....
1. Depending on what time of day I'm driving my car, I notice that my oil temps will rise to the "normal operating temp" and continue to rise to over 110 degrees Celsius. So far I haven't seen it to higher than that but I know that this temp is pretty high for just normal driving.
2. My clutch fan seems to be loud during the duration of my drive once the car gets to operating temperature and I never notice any other fans kicking on. The only time I hear that aux fan turn on is when the ac is turned on.
I know that the stock gauges are horrible at giving me the most accurate temperature to go off of but just from reading on this forum I know that my temps aren't suppose to be that high at all and it seems like I have an issue that I can't seem to pinpoint. Is that fan suppose to kick on at some point and if so does anyone know when or how to check on when it's suppose to?
Would a nismo t-stat and a bigger radiator help combat my high oil temps? Or is the solve all solution, is go buy an aftermarket oil cooler?
Thanks for all your help guys.
Kleigh
Kleigh
