Couldn't find much info it, doesn't seem like a common problem.
Ever since I swapped the head gasket,turbos, and head studs, I've had this problem.
At first I just figured it was a problem with the tune because of the turbos, but it
just feels a bit deeper than that.
The car idles fine, Doesn't smoke or backfire, smells like its running fine, but all hell breaks out when you hit boost.
Any positive pressure at all the car starts to smell pretty rich, but it pulls just fine until 10psi.
Then anything over 10psi, it backfires, misses, and lets a massive backfire when I close the throttle.
I'm pretty certain the wastegates are set at 15psi, but I can't tell because anything over 10 it loses it's mind.
Anyways, They are HKS GTSS turbos, with a test pipe, 3.5in exhaust to a flow-through muffler. It's pretty loud.
The first things that come to mind are the tune and possibly the fuel pump, but the car ran just fine on 1bar
before the swap. but i've also read that if you swap the O2 sensors you'll get some nasty backfires. I feel like there's just alot of possibilities.
Any input is welcome, Thanks!
