I started my Turbo swap last night and pulled the front pipe and all air piping (1 hour - not bad). Is it really necessary to drain all oil and coolant? My car hasn't run for at least a week so the oil should pretty much all be drained down past the turbo's. I was planning on draining the rad, but do I need to do the block too?
I'm planning to do another oil change once all is back up and running and was hoping to use the oil that is in it now as a flush.
Engine is currently installed but it really doesn't look all that bad
Thanks!
Thanks!
