Hey guys,
I'm stuck.
I have triple checked all of the wiring and it is hooked up as per Rightdrive's instructions.
From 3pin ignitor harness, white is power to new harness' power, ground new harness' ground, black w/ red stripe of 3pin is taped off.
The rest of the individual cylinder signal wires are matched up accordingly to the new harness.
The car ran fine before this except for the occasional misfire at high rpm (hence getting this kit), and has always started/is very healthy.
When I try to start the car I can hear the injectors while the car cranks and cranks, not even a couch of ignition though.
Pulling a plug to check for park there is no spark when grounding the plug.
I cannot see any blown fuses, engine bay on the plenum side as well as the kick panel inside.
Halp!
Thanks in advance.
*edit* ECU is giving me a code 21 - ignition signal and that's it *edit*
I'm stuck.
Halp!
Thanks in advance.
