I am guessing you will need to use an RB25 ECU. I am not sure about the wiring harness though... I assume you will need that too? I am new to Skylines so I am still learning
He is putting an rb26 from 33 into 32 I think you miss understood the question . Or maybe I am. If I'm understanding right, the r33 and 32 ecu s are the same however to be on the safe side id use 32 as attessa and such would be r32
Thats where I'm getting my logic from incase you want to know my theory behind it clone.
PFC is the same for r33/r32 so pinout is obviously the same. Should be pnp for either however to be on safe side I figure should use 32 since your car is 32.
If you plan to get a tune though follow what SI said and just get a pfc. You're doing swap budget a little more and allow for a nice tune to make sure engines running mint
