Well, my forged RB26 skipped a few teeth and it's now stored for winter. For now, i want to focus on my head rebuild and I have a few questions.
Background : I wish to go BW EFR 83/74 IWG 0.92. Full-race said this should give me about 620-650whp on a dynapack. Rev limiter to 8k or 8.5k rpm. The car is mostly driven DOWNTOWN or 70km/h road. I wished to do some track, but it never happened yet.. so good idle and response is pretty important for me.
*Since I don't know anything about head, I searched for infos and based my rebuild on what RAWbrokerage and PHR offer as a head rebuild package.
Machine work : I wish to have it ported a bit, but jeez...through all the thread I read so far, you have 50% of the ppl who said it could hurt the response down-low while the 50% think its THE answer to extract another 50whp/40lbs out of your setup.. However, 100% agree on the fact that if you give your engine to the wrong machinist things will be worse... so, anyone went through all this and what was your outcome ? which shop did you go with ?
Shopping list : ( Feel free to recommand me other option/parts)
1. Mine's cam baffle 250$
2. Supertech OEM-size valve set with titanium retainer 720$ ( Should I go +1mm ? or Tomei/JDM brand?)
3. Bronze valve guide 170$
4. I already had ARP head bolt, can I re-use them or I should buy new one ?
5. Spring ( I'm totally lost here, should it be single or dual spring !?) 700$
6. valve stem seal 50$
7. reinforced timing belt tomei 170$
* I see tomei sell a variety of reinforced bolt, cam stud and such... they are quite pricey so not sure its needed for my application..
** I was also considering swapping my poncam type-b 9.15mm 260 for a set of procam, but then I'm unsure if the higher lift wouldn't ruin my low-down and idle.. maybe I should stick to my poncam.
I sincerly appreciate your help because I don't wish to rebuild a 3rd time and wish to make it right this time!
