Fuel pump relay
  • Fuel pump relay
    Will a 300zx fuel pump relay work? i have a 91 GT-R and i thought that the fuel pump had quit out on me because it had stalled a few times before hand but started right back up.(the 4th time it happened i had to call for a tow) But now that i have replaced the pump nothing has changed. I also plan on hard wiring my pump if the relay doesn't fix the issue. Any other suggestions?
    Thanks mates
    Any normally open relay will work. Its not typically platform specific unless the base is a special type of connector. Just four wires. Coil energize. Coil ground, 12v+ in (common) and 12v+ out
      Awesome, yea i put the relay in but still no luck. Probably going to try hard wiring the pump now and see if that changes things
        If you want a gtr one I think I still have one in my garage hidden behind a bench
          I ended up using one from a Z32, I appreciate the offer though. Also the problem ended up being the FRCM. So i hard wired the pump and all is well for the time being
