So I thought my car was running nice, then I got to the dyno and they told me I had a missfire. While on the dyno I got a new coilpack harness just to see if that was the issue(was really close) and it made no difference. I left the shop sad, but car still running relatively nice.
This morning we went and picked it up, I had to keep my foot half way down the gas to keep it running and could barely move it to get it on the trailer. This sucked.
Got it home, I've replaced the plugs, this made it run again though extremely rough. I took off the nissan coilpacks and installed ls2 as a temporary thing. With the ls2's on the car it ran well again though still with the missfire. I pulled each cylinder 1 by 1, all of them made the revs drop except when I pulled 4. No change happened.
Then since the ls2's were just a temp placement I put the nissan coils back on to see if they ran now. Surprisingly all good. To diagnose the missfire with this I took off the plugs to each individual coilpack one at a time. Cyl 1-3 the engine almost died out as soon as the coil was unplugged, cyl 4-6 it made 0 difference. We then swapped the coilpacks(cyl 1-3 on 4-6, cyl 4-6 on 1-3), same thing. If i pull 1-3 it almost dies right away, 4-6 it makes no difference. The car ran about 200rpm less on this setup(1000 instead of 1200) compared to the ls2 coils and nissan coils original position.
My question is:
Since the car runs in either of these orientations(ls2 or either coilpack location) what can I do next to find the missfire issue?
Why when I pull cylinder 4-6 does no change happen to how the engine is running, where with 1-3 the change is instantaneous and almost dies?
How do you diagnose maf's?
My question is:
. Will have to go again soon.
