I get the wiring, what I'm wondering is can I wire the 12v ground and the two grounds parallel to where I have a short wire coming out the plug of each coil pack going into one main wire for each?
Ls2 coilpack wiring question.
I have most of the wire on and was going to connect all the 12v and grounds at the ends like it sits to the factory plug (still have to do the 2nd ground), it just seems like an excessive amount of wires. Can I leave the power and ground wires from the front coil pack long then just cut the rest a couple of inches and splice it down the first one?
what are those plug wires? i need short ones for mine too haha1992 BNR32 Skyline
Current Build:
Precision 6264 Turbo 1.00A/R
Tomei PonCam Type B
Manley Titanium Valvetrain
CP Pistons / Manley Rods
N1 water pump / N1 Oil Pump
Haltech Platnium Pro
AEM Water/Menthanol
Tomei FPR
Exedy Hyper Twin Clutch
Build Thread
Those are just the factory ls2 wires. I bought a build it your self taylor kit off ebay for 70$. its about 20 ohms for a strip that long however idon't wanna wreck my center cover so I'm going in through the ignitor hole =\. Gonna end up being like 140 ohm resistance, curious how much power loss that is in actuality.
i actually got myself a set of the truck coils (lq9?) same as ls2 with heat sync. got the same plug wires too. Gonna try to wire up this week, before i pull the engine saturday.1992 BNR32 Skyline
Current Build:
Tomei PonCam Type B
AEM Water/Menthanol
Tomei FPR
Build Thread
