When I bought my 89 GTR last month I knew that it was only working in 2WD. The seller told me that his mechanic told him that, "It's a faulty front right speed sensor". Back in those days I didn't know about the ATESSA ECU codes, so I didn't confirm the mystery diagnosis.
However, before taking the word of a mechanic I'd never met and simply sourcing a new speed sensor, this evening I set out to make progress on getting my R32 GT-R working in 4WD. I started by checking the ATESSA ECU code and didn't find anything wrong. Next I checked the fluid reservoir in the right side of the trunk and it was dry. I figured that was the issue. So I filled it (Royal Purple ATF) and bled the system using the standard procedure (bled both valves).
Now I've got a full reservoir, a hopefully adequately bled system, and still no ECU error code. However the 4WD and ABS lights are both still on.
Any suggestions on what to try next?
