Hey guys, 2 more things that have gone wrong my other R32 that I'm sure have been discussed but I just want to see what you all have to say.
Since day one, this car has had an issue where when the car has the clutch pushed in as its coming to a stop it stalls out. If the car is revved high at a stand still the revs will just drop down and stall out. This does make the car extremely annoying to drive but I've just put up with it since I just make sure the car is near 1.5K RPM before I clutch in. From what I've been reading this is a Idle Air Control valve issue? or TPS?
Another issue I have recently is that while your on the move, if you hit the gas and wait for the turbo lag, once the turbo spools it feels like the car hesitates then begins misfiring. I've changed plugs and tightened the gap, cleaned up the coils and applied the dielectric silicone to them and still nothing. Just a few days ago after lagging it would spool and pull very very hard so it was almost like this happened over night. Also worth mentioning the car felt like it misfired/rough in the morning when I would pull out of my driveway, but would go away once warmed up/
Oil Temps! What should they be? My car stays at 70c, even the Greddy gauge says 70c. I pulled the sensor out and put it in boiling water and its definitely working. Car has a Trust Oil Cooler fitted to it so could that be why the temps are barely registering over 70c? My water temp is right in the middle of the gauge while all this goes on and it doesn't move unless I run it harder than normal.
The car does have twin TD06's and theres been alot done to it back in Japan so I'm kinda stuck uncovering things as I go along...
