hey guys , spun a rod bearing and pulled my motor - I am pretty sure it is an R34 motor that was put into my R32, anyway Iv tried to find a block serial number like mine and I cant, My block is stamped "RB26 704416X with an R directly above the X" I found one bit of info on skylines Australia that stated the following :
X and then a R above is definitely a R34 Nur engine, these engine's are build by Nissan Motorsport and have the following specs in stead of the STD Rb26:
- R34 NUR cams little different then STD R34
- N1 block (24U)
- N1 piston rings
- piston + conrods weight balanced
- crankshaft weight balanced
- Nismo F112 bearings main + conrod
- N1 oil pump
- N1 water pump
The part I cant figure out is my block is definitely stamped 05U as a standard block...
anyone with some knowledge I would love to hear from you.. lol
picture of my block number
- N1 block (24U)
- N1 piston rings
- N1 oil pump
- N1 water pump
