I just finished cleaning up the AAC Valve under the intake plenum. However, now the car idles erratically. I adjusted the idle screw to bring the revs down, but it starts hunting. If I keep the idle at around 1200 rpm, it stays there, but after I warm the car up, the idle jumps to around 1400 rpm.
Do I need to readjust the TPS now after cleaning up the AACV? The car runs fine, but after driving around for a few minutes, it tries to stall on every stop sign. The revs go up and down a few times, and sometimes, it would stall, and at others, the revs would creep up to 1200 rpm. I am wondering what could be causing this issue.
Any help is appreciated.
BTW, is the thing under the intake manifold the AACV or the IACV?
Thank you,
Munib
Thank you,
Munib
