Hey everyone I just picked up mishimoto's new catch can design and I have some questions regarding plumbing... I've seen many many installation pictures and mounting options, searched and read some info regarding the subject but a couple questions I have are:
I see most people run 2 separate lines to the catch can is this necessary or can you Tee off the "C" hose that connects both valve covers and run a single line to the catch can?
Does the drivers side valve cover hose lead to a PCV valve? and if so is it okay to block that off?
My catch can only has one intake port and one exit port so I'm trying to make 1 hose from the valve cover breathers to the can... is this possible and how would you do it?
I'll also be running the vapour from the catch can to the turbo side stock location to burn it so i dont have to smell it.
Any thoughts or ideas?
Thanks,
Curt
Thanks,
Curt
