I changed my plugs today and when the car started it ran fine. I drove about 10 minutes and then parked at a friend's house, 30 minutes later I started the car and now it is having a strange issue. When it's anywhere from idle to 3k rpm it sounds almost like a motorcycle or a subaru, the exhaust noise is like a rumble.
Then when it gets into boost or high RPMs it pulls hard and the rumble immediately goes away.
Did my coils **** the bed? I feel like the coils would be worse up top so I'm curious to hear what someone thinks I should check.
I pulled the spark cover off and all the coils packs are plugged in, and the ground is tight. I was thinking of moving that sad ground spot to the block and see if that improves it? Any other ideas?
