My car came with this unit installed (attached pic). I have been trying to understand how it works and what it does, but there is no info available online at all.
Can someone please help or point me in the right direction?
A brief description of the unit. Its called VACS (Variable Airflow Control System), so I am assuming it controls airflow, but dont know how. Does it alter the TPS voltage, the MAF voltage, or both, or does it change injector flow? I havent really looked into where it connects. It has two knobs on it - control point and main volume. Not sure what control point does and where it needs to be set for the R33 GTR. The main volume knob does affect the idle speed, but it is likely it does that by altering the airflow signal, thereby causing the fuel flow to change. If the revs go higher, does it signify a leaner mixture as I have come to know?
The main point of concern for me is the setting of the control point knob, so that I don't blow up the motor or cause catastrophic damage to it.
I also have the old school Apexi AVCR installed, which was set at 0.65 bar. However, even at that level, it would actually allow the car to boost at around 0.75 bar. And when I changed it to 0.85 bar, I made over 1 bar of boost. Is that safe, assuming the car has stock turbos? Can they be run at 1 bar all day or am I looking at turbo failure soon?
And one final question - without exposing the turbos (which is a pain on these cars), can one tell if a turbo fails - loss of boost, smoke, etc..?
Thank you guys.
Thank you guys.
