Finished up my engine and sent it over to a very well known tuning shop. We are having a misfire on cylinder 3&4.
First thing we found out was the alternator is charging low (around 10 volts) That will be replaced first.
Compression checked out good across the board, same as leak-down test.
We swapped injectors, and coil packs (LS coil conversion kit) with no change.
The sparkplugs DO have some colour on them, which shows some combustion... but not like they should. If we pull fuel away from either 3/4 cylinder when car is running, there is not a big change. Unlike cutting fuel on say cyl 1, you imedally know that you cut back fuel.
Injectors are pulsing correctly as far as my tuner tells me, as well as my coils. I do have that MOJO LS coil kit that mounts the coils directly on the plugs so my tuner said to externally mount them and run wires to the spark plugs.
Other then those, I am not sure what else it could be. Did a smoke test, no vacuum leaks.
He said its possible that valve lash is too tight... Something I will double check but I know I set them up on the money (took me a good few days and a bunch of cam removing and installing)
Thoughts anyone?
Thoughts anyone?
