I've been trying to find something specifically fitting my issue and after a week decided to make a new post.
Almost 3 weeks ago I had my r32 tuned. Borgwarner single with the a/c deleted, more details are on the original owner's for sale thread here:
http://forums.gtrcanada.com/cars-sal...gle-turbo.html
I had no issues at Magnus who did the tuning. They did tell me that my engine was sweating oil so they went with 17psi making 463 and I decided to check for oil leaks before pushing it any more.
Oil change done about 1,200 before dropping it off at Magnus. Checked when I got it back, oil full to the top line still. Decided to enjoy the car and monitor daily.
On the 2nd day driving it I had a spacer completely fail in the back snapping a stud and causing some vibration. Thankfully very close to home.
At this point with the "mystery oil sweats", the damaged studs and a long overdue upper control arm install I decided to drop it off at a mechanic I have used for a long time.
A few days after I dropped it off new studs, spacers and rear upper control arms installed. Engine bay washed, no oil leaks found so they are monitoring for a day or two.
All good I think. Friday the day of the pickup comes and I get an email indicating that it keeps stalling for some reason.
Now it is the second week and no progress has been made. I was there today to check it out and when idle it just drops rpms and stalls. When I hold it at 700-800 rpm it idles smooth and warm up fine. It stalls when warm too, maybe a little bit slower vs when cold.
If I hold the clutch down when it's warm it will not stall but idle is lower than usual at ~650rpm. Normal is high-700, low-800 range.
Mechanic said nothing when he did the minor back end work which was a few days after I dropped it off. So it was still running great. As far as I know the issues started for them following the engine bay wash and checking for leaks.
Thanks very much if you have any ideas you can share.
