Hi guys it been a long time since i post something ... Anyways i have a problem that i never found the cause that i want to solve. Since i own the car (7 years) hi have a small trouble issue with the electric ... When the car idle after a few second ot start you hear a click like a relay or something and all the electric and light in the car flash for a second and the idle drop ... I know its not when the fan kick in because i already checked ... So i was thinking maby a ground trouble or something ... But he always does it when the car idle ... I change the battery remake all the battery terminal and the fuel pump is hardwire so its not this ... The only thing i think is maybe the alternator but i test it with a multimeter and it work good ... Its weird you realy hear a clicking noise and it flash and the idle drop a half second ... I dunno where to check ha and i almost forget several work have been done on the car changer headgasket rebuit turbo ... New exhaust ... Wiring specialities coilpack wire ... Maf resold ... Ecu reset ... Idle have been adjust via the iac like in the workshop ... And more but before everything ( when the car has only some hks filter and hks exhaust ) he already have the drop of voltage trouble. So maybe someone have a good idea what i can check i test a few thing but maybe i forgot something ... Thanks in advance sorry for my english haha
Nic
Nic
