Now that I have the front CV boot issue figured out, I wanted to ask experts about the three issues I have recently started to observe:
1. A few days ago, I started hearing a slight medium-pitched ticking sound when I start the car. First of all, the car is taking a bit of time starting up. The starter cranks but not at a consistent speed. And once it starts (which it always does), it idles at around 1200 rpm. At this point, if I suddenly give a little bit of gas, I hear a faint tick tick tick, which goes away after a few seconds. If I rev the engine slowly, all the way to over 5000 rpm or even more, the sound is gone. Let go of gas, give it a bit again, and the sound is back again, and then goes away as the revs climb. I know the first thought would be the lifters ticking but i know that sound, which is different. This one feels to be from not the top of the engine. After the car is warmed up, you cant hear it anymore if if you give gas, but when I start to drive it again and give gas to move, I hear it again and then it is gone. I am not sure what this could be. This happened after driving the car hard last Saturday for a few minutes. Is it possible that it is an exhaust leak from the manifold or around there? Will that go away after the car has warmed up? Or could it be the turbo wheel/fins touching the housing intermittently? Or a transmission issue, as the CV boot tore after running the car hard for a few minutes?
2. The cold start and idle are a bit rough, especially after I rev the car a few times. I unplugged each coil to see if one of the cylinders was misfiring, but the revs drop on each coil's disconnection.
3. After the car has warmed up, and I rev the engine, there is no BOV sound. Instead, I hear two sequential whoosh whoosh sounds from the around the turbos and can see air/dust flowing out of the MAF filters.
The car boosts all the way up to 1.1 bar and even more if I keep going. I have NO idea what kind of turbos it has, as I bought the car as it is. What do I need to remove to identify the turbos? Since it came directly from Japan and I am the first owner in Canada, it has quite a few visual upgrades. I am not too sure mechanically, though. When I bought the car in January, it ran great and none of these problems were there. It's a different story now.
Can anyone give ideas as to what's goin' on? What should I check? I hope these are not very dangerous signs or symptoms of some catastrophic failure lurking in the shadows.
Please help me as these issues have me totally stumped.
Thank you.
Thank you.
