Tips on separating the transmission from the rb26?
  • Tips on separating the transmission from the rb26?
    So before I posted I tried searching around but can't really find much on this. I am trying to separate the tranny from my motor. Engines already out but having troubles pulling the trans off. I rotated it 45 degree's tried pulling. Used a pry bar along the edges to separate but it doesn't seem to want to come out and slide off. Does anyone have any tips or anything to do this or something. All the bolts are off the bell housing.
    Thanks guys!
    91'- GTR - SOLD
    94'- GTR
    It pull type clutch ?? You need release the bearing from the pusher plate, here how remove black rubber on top of the tranny take screw driver pass throu the bellhousing and place right bettween de release bearing and the pusher plate. Here example how to remove the bearing,it from subaru but it the same thing! http://youtu.be/gBi5B_jVVGU
