Help me get my horn working
  • Help me get my horn working
    Hey guys,
    So i have a 96 33, and the previous owner put a lot of work into the car, but, No HORN! Horn delete anyone??
    Im trying to get the horn back up an going and am running in circles.
    My fuse box has been hacked away and there are a few custom relays in there, but i do still see a smaller black fuse/relay, which i'm assuming is my horn.
    On the radiator suppose, there is an exposed green wire, which i'm assuming is the horn power.
    I tested that wire as well as the black fuse for power when the horn is pressed on the wheel, but there is no change in voltage
    any help is appreciated.
    thanks!
    Run a new wire off a relay from the switch on the steering wheel. Fastest way
      that was my plan, but i cant figure out the polarity. I've tested all 4 for a 12v signal when the butting is pressed, without success.
        So doing some research and troubleshooting, The relay under the bonnet will click if its engaging. THe orange wire is a ground that runs from the horn, and triggers the relay to close when pressed.
        My horn is not triggering it. I grounded it to the chassis and it clicked. So my problem is up stream from the relay.
        Ive been reading some thread across the internet, and the words "HICAS Ribbon behind the steering wheel" have come up. my Airbad light is also on.
        Any advice?
          Is there an aftermarket wheel installed?
            No.
            Going throught some more ****, the boss must have a break in it. Also, there is no airbag in the airbag wheel lol.
            The yellow to the relay is also not there.
            oh well. gonna wire in on of these:
