Repairs Help?
  • Repairs Help?
    So i got an inpsection and the mechanic
    said that i need to replace Rear inner tie rod ends and front
    upper ball joints.
    and he quoted me around 700 for labour and 700 for parts.
    He also mentioned that he couldnt get any of these parts from a 300zx.
    but i was searching last night and i thought that the tie rod ends and ball
    joints are the same for a gtr.?
    any help guys
    if its 700 of labor to change a rear tierod+ balljoint then....its not cheap labor....as for yhe tierod its suposed to be the same as the 300zx one........the ball joint I belive it is the same but not quite sure since as for an exemple the upper arms dor the 300zx are almost the same as the gtst ones but there is a minus difference.....so it might ve the same for the ball joint......maybe someone can confirm
      jsut to clarify that it is both upper ball joints in the front
      and both rear inner tie rod ends
      and he also said that the rotors will have to be replaced soon?
        I need to replace both rear ball joints at the end of the HICAS bars, and im also trying to find out if the 300ZX ones are the same. Does anyone have a definitive answer to this? :P There $80 each if I have to get the GTR ones Im hoping the 300ZX ones are the same
