I know this is the dumbest possible thread but I cant figure it out! I push the AC button and it says "18 degrees C." THAT AIN'T COLD B***H! and if i tell it to go colder by pushing the cold arrow nothing happens. Also, my ambient temp thinks its -30 degrees outside. in may. its +30C here. But i don't care about the ambient thing. How do i make it cold?!?
How do i turn on my AC???
If AC needs a recharge, AC will feel warmer when you turn on aircon -
If you press AMB button, it gives you ambient temperature in the cabin. Press AC button then auto button. Then I think was up and down arrow to select temperature.
Sometimes the headunit has bad solders behind it and plays up if it's been in the sun alot (common age related problem). I had a link to a how to on repairing this problem, but can't find it.
Or could be the sensor, which I think is located on the bottom right of black plastic trim that's around the centre console. It has a small grate looking vent in the plastic trim.RESPONSE MONSTER
if it's just a burnt fuse i hope its not because of a problem with the AC. my porsche 944 kept burning the AC fuse because something was wrong with the condenser. it wouldnt be the end of the world if it didnt work though, i like the wind in my lack of hair anyway.I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
My temp only goes to 18c and does not go lower. I push the AC button and I can see and feel the revs twitch as the condensor kicks in and it blows cold air.Originally posted by m_melen View PostI know this is the dumbest possible thread but I cant figure it out! I push the AC button and it says "18 degrees C." THAT AIN'T COLD B***H! and if i tell it to go colder by pushing the cold arrow nothing happens. Also, my ambient temp thinks its -30 degrees outside. in may. its +30C here. But i don't care about the ambient thing. How do i make it cold?!?
i checked out the relay, there's connectivity between terminals 1 and 2 as indicated on the top of the relay, and that's all. should there be connectivity between other combinations of the terminals?I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
