Avoid external wastegate on stock exhaust manifold. It makes engine harder to tune with stock ECU (From memory a tuner mentioned something along the lines of stock ECU hasn't got enough rpm adjustment points on maps). It's not so bad if you had a ECU like Link G4, Motec ECU, as I gather it makes it easier to solve the tune problem, due to more rpm adjustment points on maps.
Internal wastegate actuator should be ok for your application. They use internal wastegates on GTS-R (with similar type of turbo). If you have boost spike problems, enlarge the wastegate port on exhaust housing, fit bigger wastegate / flap assembly. Up to 400hp it's a waste of time and $$$ going external wastegate. SR20DET's achieve 440hp at engine with GTRS turbo, 1bar HKS internal wastegate actuator, cams, etc.
They don't actually mention fully how to tune a ECU. That comes with experience / training or learning off somebody that has experience / training.
